Hi All,
I'm hoping someone can point me in the right direction.
I have debossed some text on my model. The text sketch is fully constrained and it appears to deboss ok. However, when I export to .STL to 3d print it does not include the text?
I have done some other debossed text test pieces and these have exported to .stl & printed fine.
The text shows on the model face but does not have the debossed appearance as my other test pieces did? What am I missing.
Paul
Solved by dsouzasujay. Go to Solution.
Hi @Anonymous ,
Can you attach the design here to a Reply that you have already completed in Fusion 360?
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaHi @Anonymous ,
In the attached file "Ampule Breaker Velcro Fixture v9.f3z" there are 2 bodies overlapping on each other.
If you hide "Body6" and "Body2" and then save as stl should generate mesh with debossing.
Edit: Attached the exported stl body
Sujay D'souza@dsouzasujayThank you for fixing this!
I'm sure there was probably a better way to model my fixture but it is all part of the learning curve.
Paul
