Curved Line
Curved Line
sanderdb01U85VP
Curved Line
sanderdb01U85VP
I have a very simple, and hopefully not dumb, question. Is there a simple way to create a curved line like that in Sketch (mac program for graphic design) or Inkscape? In those programs, any line can be converted into a sketch by clicking any point on the line and dragging it. I would eventually like to import a picture into Fusion, sketch out the outline of the object with basic lines, further refine it by clicking the dragging the points of the lines to move them and make curves, and then extrude it. Any ideas anyone? Thanks a bunch.
davebYYPCU
Sure,
Import the picture, using Insert menu,
create a sketch, on the image position,
use lines, splines, arcs and circles to trace the image, and then extrude when sketch is finished.
Should get you started.
sanderdb01U85VP
So there is no way to make a curve out of a straight line then? Meaning, sketch it straight, then modify by putting a curve in it
Thanks for the reply btw
TheCADWhisperer
Spline - two endpoints.
Then drag the fit points or Handles on the fit points.
Add Fit Points as needed.
Thanks all!  Combining all the answers, I've done it.
Much Obliged,
Nick
