Dealing with Safety Factor issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, Im modeling out a machine and am using Simulations to refine and test the design. At this point I have it pretty solid and when testing Im getting less than .1 inches deflection over a 10 foot span etc. Almost entire machine is cool blue with almost no stress, but safety factor reads in the toilet due to little tiny spots at the inerfaces of some components where there would normally be a weld bead to spread the load out evenly.
Can anyone suggest a methodology to clean these up, ignore them or otherwise make them not tank my Safety estimate without having to work through the entire machine creating weld beads and pentration simulations which could take more time than it took to design the machine.
Gut says this thing is plenty strong but I cant generate a report to back that up. Note in the picture below a view of the failure spot. its at the edge of a 3" wide tube that mates to an 1.25 steel plate boss. once welded there is no way this will fail. For what its worth the machine is loaded with a 7000lb off axis load and you can clearly see how stress free everything else is and how concentrated the trouble spot is.
Any thoughts?
