Data Panel is screwy...
I am not seeing anything in my Data Panel.  A little over an hour ago I started using Fusion again since last Friday before the big update on 5/7/2016 and now my Data panel is blank.  I can't even go into  offline mode mode because it says it is I am currently uploading a file.  I am not sure I am and the scary thing is my Data Panel is blank.  Yikes!!  if you look at the sreen capture you will notice the data panel is blank and I have the error posted
I have read a couple post about blank data panels but they are not helping me.
Looking for help.  🙂
I have also attached a diagnostics log I just made.
Hi Tommy,
Can you try the following?
1. Click inside your Data Panel, hold down the Fn key and hit F5?
2. If that does nothing, can you restart Fusion 360?
If still nothing, please post back and we can try one other thing.
best regards,
Sanjay Jayabal.
Turns out Fusion was updating in the backround.  I ended up walking away for about an hour and looked at my computer and fusion had just started installing the update.  After the update was completed I restarted Fusion and averything was back to normal.
I am wondering if there is a download indicator to let the user know what is happening so that unnecessary confusion can be avoided.
Thanks for your help!!
