Cutting/Shaping Concave surface
Message 1 of 8
Trying to Combine/Cut in the interior concave surface with another highpoly object but Fusion wont let me make that command.
Replies (7)
Message 2 of 8
lichtzeichenanlage
It would be nice if you could share the design. Is your high poly object a stl file?`
Message 3 of 8
TrippyLighting
Af first "sight" I'd suggest to use Meshmixer.
Message 4 of 8
Yes, it is an .STL. I've done the usual from various tutorials. "Do Not Capture Design History", Import Mesh, Mesh to BRep. Tried projecting using various choices, but that doesn't seem to want to do as I like. Doesn't allow me to use the baseball as the cutting tool.
Message 5 of 8
Not sure where to start from there if this is an easy option.
Message 6 of 8
TrippyLighting
There is an easy option. Use Meshmixer.
.stl is NOT a CAD format. Fusiosn 360 is a CAD software.
Message 7 of 8
It's not exactly the level of precision I was looking for, but thank you. I've manage to get it to work in Meshmixer, though I've no idea if anything is centered properly.
Message 8 of 8
TrippyLighting
By definition triangulated meshes are not precise. Such meshes have a finite resolution. If you have access to the original quad mesh this object might have been modeled with then that opens up options in Fusion 360.
