Cutting element
Cutting element
Cutting element
Hello!
I am new here, and just starting with fusion 360 ( inventor was before:) )
I want to cut inside the element a spiral, could You tell me how to do that easly?
I just draw an element (circle) and i need to cut this blue spiral (please take a look on screen shot)
any ideas?
Thanks for help!
JDMather
Are you attempting to Sweep-Cut a circular profile along that "spiral" path?
Can you File>Export the *.f3d file to your local drive and then Attach it here?
You will have to make your profile sketch small enough that it will not self-intersect as it sweeps the "spiral".
Now if you want a real Spiral - go into the Coil command (just like in Inventor)
Hello, the problem which i get with spiral is that, i cant do a hole through in this shape (circle). i need to do this like You did, This line is only a way how this hole need to looks like. Of cource the shape of the cutouts (line) must be thicker .
JDMather
Can you Export and then Attach your *.f3d file here and give exact specifications that you need.
(If you can't figure out how to do it in Fusion, attach your Inventor *.ipt file here since you have experience with that program.)
