first of all, thank you very much for your answers.
My working environment is as follows: INVENTOR license expired, all INVENTOR programs deleted from local computer, .ipt files in different folders, FUSION single user version for private use without license.
It is not possible to open an .ipt file (as described by jhackney1972): It gives the error “This file type cannot be opened”.
I have now found a (very complicated) solution:
- upload .ipt file
- Insert the .ipt file into a new solid
- Save this file
- Open this file with a double click
- Export this file to the local computer as *.f3z (no other FUSION format is possible)
- Unpack the archive (with 7-zip)
=> I get two .json files and two .f3d files
- Upload first .f3d file
=> Paste cut-out does not work
- Upload second .f3d file
=> Paste cut-out works
This procedure is very cumbersome, but at least I can continue to use my existing .ipt files.
I have attached the two .f3d files. If you have a better approach I would be happy to hear from you. Otherwise, thanks again for your support.
Rudi
Translated with DeepL.com (free version)
