Cut , and Hole in Assembly Fusion 360
5 REPLIES 5
gyuneshmehmed
1414 Views, 5 Replies
Do you can cut hole in Fusion 360, because I try and I can't do it.
Тhank you in advance
5 REPLIES 5
g-andresen
in reply to: gyuneshmehmed
for me, it looks like an existing hole is bigger than the new cut profile. Then there is understandably no more hole to create. If it should not be the case, please share the design.
günther
chrisplyler
Try checking in here....
It is possible that you might have one Component active, having put your sketch into it, and you're doing the extrude/cut within it, but you're trying to cut through a different Component.
gyuneshmehmed
in reply to: chrisplyler
Thanks for Reply
I try everything but I can't to cut detail in Assembly.
Please, if anyone know how to do,to help me by showing it in a video.
davebYYPCU
I try everything
No Sir, you have to change these links first.
Might help.....
chrisplyler
in reply to: davebYYPCU
@davebYYPCU wrote:
I try everything
Might help.....
And then ACTIVATE the one you want to cut. All actions you perform are done on the Component that is currently active.
