Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Cut , and Hole in Assembly Fusion 360
5 REPLIES 5
gyuneshmehmed
1450 Views, 5 Replies
gyuneshmehmed
Do you can cut hole in Fusion 360, because I try and I can't do it.
Тhank you in advance
5 REPLIES 5
g-andresen
in reply to: gyuneshmehmed
g-andresen
for me, it looks like an existing hole is bigger than the new cut profile. Then there is understandably no more hole to create. If it should not be the case, please share the design.
günther
günther
chrisplyler
chrisplyler
Try checking in here....
It is possible that you might have one Component active, having put your sketch into it, and you're doing the extrude/cut within it, but you're trying to cut through a different Component.
gyuneshmehmed
in reply to: chrisplyler
gyuneshmehmed
Thanks for Reply
I try everything but I can't to cut detail in Assembly.
Please, if anyone know how to do,to help me by showing it in a video.
Thanks for Reply
davebYYPCU
davebYYPCU
I try everything
No Sir, you have to change these links first.
Might help.....
I try everything
Might help.....
chrisplyler
in reply to: davebYYPCU
chrisplyler
@davebYYPCU wrote:
I try everything
Might help.....
And then ACTIVATE the one you want to cut. All actions you perform are done on the Component that is currently active.
@davebYYPCU wrote:
I try everything
Might help.....
