cut & paste
cut & paste
cut & paste
Can we do cut and paste some of the faces from one body to the new body?
For example  : Copying door faces form the vehicle body to other layer.
AndrewSears
Can you attach the Fusion 360 file to this post?  We will be able to look at your scenario and offer some suggestions to reach your end goal.
Andy
Refer the below link for the file
www.dropbox.com/s/yi9x03ritt9jsg1/Basic%20car.f3d
This file contains just a basic volume of the car in which  if the green house can be cut & paste  seperately to a different layer , as it does not require much more resolution .
Because of the form complexity the remaining body requires more resolution which can be added easily with out increasing the green house resolution
AndrewSears
Ok.  Thanks for the file.  now I understand what you are trying to do.  I will email you the video showing the steps.
Andy
Thanks Andrew sears that was helpful
