Error T point
Error T point
Error T point
Hello everyone ,
I am a new bie to fusion 360 and i am trying to model a car,
when i try to smooth the model from the box mode  using Alt+3 it is not happening
So i tried to find the problem using repair body in which it shows i have a T point error at three areas below the wheel arch
flange area .
Need help in finding the solution to this points . Refer the attached image
innovatenate
Autodesk Support
Autodesk Support
Could you use the export archive command and then upload the F3D file to this forum posting?
Nathan Chandler
Principal Specialist
Refer the below link for the file
https://www.dropbox.com/s/yi9x03ritt9jsg1/Basic%20car.f3d
deyop
In the version you provided us it looks like you may have selected the AutoRepair and the Error T was resolved.  However I did see the creasing problem that can be associated with having an interior corner.  Here is an image of the area I am refering to.
This can be addressed in a couple of ways.  You could remove the faces that create the interior corner or select all the surrounding edges and extrude them in Edit Form (Alt key) move.  This is a bad characteristic of T-Splines we are working at removing.  We have prototypes now that will eliminate that problem with interior corners.  I put an image of the results of our prototype.  This will be available in a future release after testing insures stability and interaction with all commands will be safe.
Nice start on your car model.
