Customized environment colors
Damien_Deline
Damien_Deline
is it possible to customize the environment colors easily? I like the grey room environment as it is easy on the eyes when you're using Fusion for hours and hours but the one issue is Driven dimensions are very hard to see.
I saw a while back that someone had coded their own dark mode GUI for fusion in a couple hours so I imagine that it wouldn't be that hard to change the color of some text.
photo to show the Driven Dimension text
jhackney1972
I also use the Grey Room environment and I have changed the certain display colors in it.  If you like the colors I show in the screen capture, you can replace the Greyroom.xml file with the one I attached.  I recommend that you copy the original to a safe location before editing or replacement.  It is easy to change to other colors using a good text editor.  I am using Windows, I cannot give you the location of this file on a MAC.
Edit: Of course all these changes are done when Fusion IS NOT RUNNING!
Please note, the red arrow indicates the Windows Username which will of course be different from yours.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
Damien_Deline
I had a feeling that someone had taken the initiative on that one . Much appreciated !
