- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've seen this issue with other users, for example in a topic of 2016. I'm using Fusion 360 for creating labels on my bookshelfs with Nintendo stuff.
So I used several Nintendo look-a-like fonts like Pretendo and Spritendo. They show up under the fonts and I can add text. But when I want to extrude them, that is not possible. It says "Cannot complete extrusion". The more info says only the same.
In the 2016 topic I read something about creating an SVG and import that. So, I created an SVG file with the text, inserted it and it ended up with the same error. When this method worked, I would be helped, but unfortunately it isn`t the case. Other fonts are working, but I tried everything and looking at the communities like Thingiverse, other programms did not have the issues with this font. Also using a "font fixer" does not change anything.
