Split Sketch from SVG import
monbleau
monbleau
I have a SVG I imported that contains 4 objects.  All separate
I want to split it into 3 separate components so I can send to my 3D Printer and print in different colors.
It's a basic circle base with the image on top that I want to extrude out a couple mm.  I need the Beak parts in one component, the eye in another, and the feather in another component.
Attached is the file.
jhackney1972
Extrude each in turn as a separate component.  I use an Extrusion of 1mm which you can change as desired.  Model attached.
John Hackney, Retired
