Curved Tapering Profile
Message 1 of 10
I'm trying to replicate some elements from a book cover of mine as 3D models for a potential 3D printing project. The image is below.
Now, for the gem part, I'm pretty happy with what I've got. But that curved tapering bit is a real pain. I tried a sweep, but it's a non-uniform width, so if I use scaling the thickness isn't a smooth decrease, and I can't get it to go to the very end without erroring. Next, I tried a loft from a starting profile in the center to the point at the end of the curve, but again, the non-uniform thickness means just using a center-line makes it too narrow to match the image. I created an angled plane through the endpoint and the top of the profile, and then used three curved rails to shape the loft, and it got SUPER close, but there's a weird wrinkle on the top of the curve.
Any thoughts?
Replies (9)
Message 2 of 10
HughesTooling
You might be able to get what you want with extrude tapered, see attached file.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
HughesTooling
Mark Hughes
Message 4 of 10
That does come super close. Certainly close enough to satisfy me, but in my instance the tool body fails to create if I complete the taper entirely. As you can see, there's the tiniest of top surfaces on mine. I may be able to deal with that just by tweaking the original profile slightly. Thanks!
Message 5 of 10
TrippyLighting
This should be dead simple to do in the patch workspace.
Maybe the screencasts I created in this thread can give you an idea as in general the problems are very similar.
Message 6 of 10
That works exceptionally well too, though there's a tiny little "weird wrinkle" on the inside curve where the shape bulges out a little. It's super small, but you can see what I mean in the cross section analysis, where it's convex rather than a straight line.
Do we know what causes that sort of thing and how to mitigate/avoid it?
Message 7 of 10
davebYYPCU
I think the loft tool has a tendency to stretch it's result, and the profile is being "pulled" to the inside of the curved rail,
I have done it with this file the way you are looking for, straight sides, same curves as the canvass,
(had a little drama with one sweep, had to delete half of the model, and have to mirror now,)
Might help .....
Message 8 of 10
Oh, wow. Interesting solution. Clearly I have to get a little more familiar with patches.
Message 9 of 10
davebYYPCU
Yeah, Patch is a little more forgiving, but more work - if you get what I mean.
Did it this way, to allow for varing height on the middle rail  just a bit, the centre profile is lower than at the middle section in front view.
Happy to help,
Message 10 of 10
TrippyLighting
The thread I inked to has two screencasts. In the second one I am not using the loft tool.
You can simply create a patch!
If you don't want a "flat" patch, because for example you might want the shape to be scalloped (concave) or cupped (convex) you can simply use a loft with rail, which will provide predictable results.
