Curved Slider Joint?
Just wondering if there is a way to get the blue piece to slide along this curved object. Thanks
masa.minohara
Hi @Anonymous,
Welcome to Fusion community, and thank you for posting this! Unfortunately it is not possible to do it in Fusion 360 at this time, as far as I know. You may consider submitting your idea to the Fusion IdeaStation forum, which is constantly monitored by developers and product managers, and is currently the most effective way to request a product enhancement:
Other forum users will have the opportunity to Vote or add Kudos to the Idea. Votes on an idea will increase the likelihood that an idea will be implemented.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
TrippyLighting
If the curve is a segment of a circle no slider joint is needed. You can simply use a revolute join between the center of that circle and the blue piece. you can n add a joit origin to the blue piece offset by the radius of tat circle.
If the curcve is a spline, then currently that cannot be done. Here is a quiclk selection of entries in the Idea Station:
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/curved-slider-joint/idi-p/6234242
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/movement-along-tracks-paths-and-tele...
Please throw your vote in the hat(s).
