Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
curved case
2 REPLIES 2
434 Views, 2 Replies
curved case
Hello everyone ,so i'm trying to create this case with fusion but i have a problem with the edges i want to create this smooth curved shape but i end up with having edges i've tried using sculpting but i can't figure it out i'll upload  picturesCapture.JPGCapture2.JPGCapture3.JPGFZN15J1JCAUC1H4.MEDIUM.jpg of this shape that i've created so far maybe you can help i just want to have this oval smooth shape that goes from the bottom to the top from all 4 sides instead of the edges, i've uploaded pictures of the shape i've created so far and a picture of a case that i want to create and i hope you can help, thank you
Tags (1)
2 REPLIES 2
Use 2 point curve for upper surface then extruded it and you will get the desired shape which you want.
Hope above information helps you!
Thank You!!!
There are many ways to approach this, surely some better than others. I would suggest to avoid sculpting, since the form appears quite regular.
One route:
  1. Create an arc (tangent to the horizon) that your can revolve around the center axis. This should create something akin to a contact lens.
  2. Then boolean that form with an extruded form in the shape of the top view of the case. This will result in a dome-like form, trimmed to the constraints of the case, kind of like you took a cookie cutter to your contact lens.
  3. Join this top portion to any other geometry that you need for the rest of the case's structure.
Hope that helps a bit 🙂
Technology Administrators
