Hello everyone ,so i'm trying to create this case with fusion but i have a problem with the edges i want to create this smooth curved shape but i end up with having edges i've tried using sculpting but i can't figure it out i'll upload pictures of this shape that i've created so far maybe you can help i just want to have this oval smooth shape that goes from the bottom to the top from all 4 sides instead of the edges, i've uploaded pictures of the shape i've created so far and a picture of a case that i want to create and i hope you can help, thank you
Use 2 point curve for upper surface then extruded it and you will get the desired shape which you want.
Hope above information helps you!
Thank You!!!
There are many ways to approach this, surely some better than others. I would suggest to avoid sculpting, since the form appears quite regular.
One route:
Hope that helps a bit 🙂
