Curve continuity issue when exploding Text
jean-michel_legoff
Message 1 of 22
jean-michel_legoff
When exploding a text, Fusion360 try to generate curves from the glyph, but for any reason, converted curves lose tangency constraints.
here some results of the vectorization of the "&" in "Forte" typeface:
attached below, I get both in a single file and you can see the difference between the 2 vectorization.
the issue is that if surfaces generated by extrusion are not continuous and create some rendering artefact and issues when you try to round the edges or offset the surface.
could it be possible to enhance this feature and generate true tangent Bezier curves?
Many Thanks
Replies (21)
Message 21 of 22
terry_fusion
Yeah, that seems to be the case.
Personally, I don't think that it should be said that its been fixed internally and will make it downstream to the users, that makes it seem like its only months away, rather than years.
That said, I literally cannot do the work in Fusion that is vital to the operation of our company, if Autodesk feels so little commitment to their users that they can't commit more resources to it,  then its about time to find another solution for our work.
Message 22 of 22
terry_fusion
4 years on and fonts are still a mess, I can't even use Fusion in my work for that, and thats our main thing.
@terry_fusion -this post has been edited due to Community Rules & Etiquette violation.
