Curve continuity issue when exploding Text
jean-michel_legoff
Message 1 of 22
jean-michel_legoff
When exploding a text, Fusion360 try to generate curves from the glyph, but for any reason, converted curves lose tangency constraints.
here some results of the vectorization of the "&" in "Forte" typeface:
attached below, I get both in a single file and you can see the difference between the 2 vectorization.
the issue is that if surfaces generated by extrusion are not continuous and create some rendering artefact and issues when you try to round the edges or offset the surface.
could it be possible to enhance this feature and generate true tangent Bezier curves?
Many Thanks
Replies (21)
Message 2 of 22
jeff_strater
long-delayed follow-up:  It turns out that you did, indeed, discover a bug in the way that Fusion was extracting curves from a font.  That bug has been fixed internally, it will take some time for it to make its way to a production build
Before:
after:
Jeff Strater
Engineering Director
Message 3 of 22
jean-michel_legoff
hi,
looks great, any chance to get it in beta(preview) before it comes in “production”?
thanks
Message 4 of 22
helfenj
@jean-michel_legoff,
We will likely roll the fix to product without a "beta" as it isn't typically required for bug fixes.
As soon as this fix is available we can let you know.
John
Message 5 of 22
jean-michel_legoff
Hello, @helfenj
I was expecting the resolution of this bug in this March update... but unfortunately it is not there.
Have you any idea how long we shall have to wait for it?
Instead of a beta, could it be a "preview feature" to be activated in the prefs?
Many Thanks
Message 6 of 22
jean-michel_legoff
Hi, @helfenj , @jeff_strater
Am I wrong when I say that in the April's update, extruded editable text were correct (tangent curves) as well as exploded text curves?
Now it looks like you need to explode text in order to keep the tangency continuity of the curves.
Why this behavior?
Message 7 of 22
jeff_strater
I do not think that anything changed between then and now.  I see the same geometry on directly extruded text and text that has been exploded.
do you have an example model that shows that directly extruded text has different continuity than exploded text?
@rohit.bapat - you were involved in the original fix.  Do you have any reason to believe that this has regressed at all?
Jeff Strater
Message 8 of 22
jean-michel_legoff
Yes it's simple to see the difference...
try to round an edge or analyse the curvature of the edge...
Message 9 of 22
jean-michel_legoff
is there still some development about this issue?
Even if exploding text in the sketch could be found as a workaround, it's a pity to have to explode the text when you need extruding it clean.
In some case, when the text must remain editable you break associativity if you have to explode it.
I'm using custom glyphs as logos to engrave parts.
@jeff_strater
Message 10 of 22
jeff_strater
no, there has been no change in this area.  In all honesty, it is not a high enough priority right now compared to many other issues, so I don't expect this to change in the near future.  Sorry not to have a better answer
Jeff Strater
Message 11 of 22
jean-michel_legoff
About Text, I have another request.
is it possible to export a "text" as real "text entity" in the DXF when exporting a sketch?
for any reason I get only a n empty rectangle instead of a text.
Many Thanks
Message 12 of 22
jean-michel_legoff
I was wondering if this topic could be reactivated?
If it has been almost resolved , it may be enhanced a little.
It's still an issue to have to "explode" text before using text as a profile...
It should be nicer to be able to extrude "text" as is, and keep "tangent continuity" between faces...
Many Thanks
Message 13 of 22
jean-michel_legoff
Is there any enhancement on this topic?
Until now, even if the issue has been a little corrected, the curves are still recomputed and mostly subdived in 2 to keep tangency. But the worst is that this correction occurs if you "explode" the text in the sketch.
If you don't you keep the first behaviour e.g. the curvature/tancy coninuity is lost.
Could it be possible to rework on this topic? and use text as fine as it is done in the other Autodesk Softwares Alais, Maya, 3DS Max? ...
Many Thanks
Message 14 of 22
MichaelT_123
Hi Fellows, Collègue J-M_L,
The issue still annoys some, like … a pebble in a shoe.
What is the nature of the problem? I mean … technical one.
Font glyphs are defined by a collection of (poly)line segments and Bezier curves with point coordinates limited to a grid of limited size (16x16, 32x32, …).
The underlying algorithms must be very efficient computationally and in terms of memory utilization.
The right image of the foundation post is an excellent example of it.
The Bezier curves mentioned can be quadratic and cubic types … with an efficiency trick implemented. When two quadratic representations are codded in succession… they are together considered as a cubic type.
Looking at the right image, it seems that F360 renders two quadratic Beziers separately instead of performing the necessary trick.
Here is a way to do it: extracted from FreeType code depository: https://git.savannah.gnu.org/cgit/freetype/freetype2.git/tree/src/base/ftoutln.c
The following excerpt of the code and its implementation by TF360should throw the pebble away.
      /* check first point to determine origin */
      if ( tag == FT_CURVE_TAG_CONIC )
        /* first point is conic control.  Yes, this happens. */
        if ( FT_CURVE_TAG( outline->tags[last] ) == FT_CURVE_TAG_ON )
          /* start at last point if it is on the curve */
          v_start = v_last;
          limit--;
        else
          /* if both first and last points are conic,         */
          /* start at their middle and record its position    */
          /* for closure                                      */
          v_start.x = ( v_start.x + v_last.x ) / 2;
          v_start.y = ( v_start.y + v_last.y ) / 2;
       /* v_last = v_start; */
        point--;
        tags--;
... and by looking at the code simplicity ... the implementation should be brisk&quick, shouldn't it, Mr Strater :).
Regards
MichaelT
MichaelT
Message 15 of 22
jean-michel_legoff
You may be right, but the tricky is that even if FT360 as enhanced a little the way Bezier curves are converted, this happens only if you explode the text manually in the sketch...
It's not happening when you extrude the profile on the fly...
Message 16 of 22
MichaelT_123
Fusion (as I understand) delegates  Fonts/texts/glyphs processing to OSs which implement their own independent procedures,
However exploded glyphs are brought to Fusion domain. It seems that there is some inconsistency in the explosion procedure.
MichaelT
Message 17 of 22
jean-michel_legoff
Is there any enhancement on that topic?
The worst as I already said is that the fonts are well expanded in other Autodesk Package like Alias or Maya, and even 3DS Max I guess...
Why Fusion 360 can't use the same tools.
It's really a pity to be able to "explode" the text in the sketch, losing the way to edit the text parametrically.
and use the font as profiles.
Message 18 of 22
terry_fusion
So is this going to happen anytime soon? It's been almost 4 years?
Seems to have dropped through the cracks/
Message 19 of 22
jean-michel_legoff
I'm afraid, that it is not on the top of the pile...
Message 20 of 22
jean-michel_legoff
The worst is that all Autodesk Tools works fine with fonts (Maya, 3DS MAx, Alias...)
