Cube in upper right corner dissapear when moving an object
4 REPLIES 4
oyvind
517 Views, 4 Replies
After the last update.
If I want to move an abject, the orientation cube is gone
If I close the file and reopen it, the cube is there until I try to move an object
Is this a known problem? A fix for it?
Before I use the move toolBefore I use the move toolWhen I use the tool, the cube is goneWhen I use the tool, the cube is gone
4 REPLIES 4
SaeedHamza
in reply to: oyvind
I think it's clearly a bug
There is no way to hide the view cube
rohit.bapat
in reply to: oyvind
Hello @oyvind
Thank you for posting your concern. We have a ticket (FUS-39560) which the team is already working on. Could you please attach the f3d model? It will help us solve the problem very much.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
oyvind
in reply to: rohit.bapat
It is not related to my 3D model.
I did a new test today - started a new 3D model, and inserted a simple cube, then the "orientation cube" disappeared.
Phil.E
in reply to: oyvind
@oyvind
Do you know where the "inserted cube" is in relation to the origin? I ask because the only way I know of to remove the view cube is to insert something very far from the origin. This tends to happen with sketches or DWG information inserted, where in the source file the origin is very far from the geometry.
What happens when you start a new design and draw a cube on top of the origin?
Phil Eichmiller
Software Engineer
Quality Assurance
