After the last update.
If I want to move an abject, the orientation cube is gone
If I close the file and reopen it, the cube is there until I try to move an object
Is this a known problem? A fix for it?
Before I use the move tool
When I use the tool, the cube is gone
I think it's clearly a bug
There is no way to hide the view cube
It is not related to my 3D model.
I did a new test today - started a new 3D model, and inserted a simple cube, then the "orientation cube" disappeared.
Do you know where the "inserted cube" is in relation to the origin? I ask because the only way I know of to remove the view cube is to insert something very far from the origin. This tends to happen with sketches or DWG information inserted, where in the source file the origin is very far from the geometry.
What happens when you start a new design and draw a cube on top of the origin?
