crumpled object
crumpled object
abiliofernandes097
Message 1 of 11
crumpled object
abiliofernandes097
Hello
I do animation in Blender but use Fusion for modeling.
I would like to know how you would create defects/dents in an object's mesh in Fusion, like in the image below.
mainly on the edge as marked in the red circle
Thank you.
Replies (10)
Message 2 of 11
kacper.suchomski
Hi
Yes, you can simply sketch such a trace on one face and use the Revolve operation in cut mode to remove the material.
(view in My Videos)
Kacper Suchomski
Message 3 of 11
abiliofernandes097
Is there a way to apply this defect to multiple parts of the object at once? In random locations?
Message 4 of 11
kacper.suchomski
If you model it, you will have it modeled.
Kacper Suchomski
Message 5 of 11
abiliofernandes097
Is there any command, for example: random, to type in the value of a resource, for example: fillet size, to apply fillet to different lines with different sizes at once?
Message 6 of 11
TrippyLighting
I would suggest you use a displacement texture in Blender to apply such imperfections!
Message 7 of 11
abiliofernandes097
the mesh is very subdivided/heavy
Message 8 of 11
kacper.suchomski
In the fillet dialog box, you can specify multiple places assigned to different values ​​in one command; but I don't see the relevance of this tool to your topic.
Kacper Suchomski
Message 9 of 11
abiliofernandes097
to fill each dent with a different value, to make it more natural
Message 10 of 11
TrippyLighting
Understood!
Creating such features as actual geometry is much more problematic in CAD than in a Mesh based software such as Blender!
For visualization purposes, usually a bump or perhaps better a normal map are the right tools. There are quite a few plugins available to help with that in Blender.
Message 11 of 11
kacper.suchomski
But this isn't Fillet, it's Revolve.
Yes, you can draw multiple regions in a single sketch as long as they all lie on the same plane.
Kacper Suchomski
