Creating triangles?
Creating triangles?
Creating triangles?
So i have this in fusion 360: fusion.jpg
I would like to know if there is a feature that can do this:
So that i can then extrude the triangles downwards and cut them off at the bottom. Does anyone know of a way to do this, or a better way than this?
SaeedHamza
I can't understand what you're after
Please share a picture of the result you're trying to achieve so that we know if the approach you're trying is the right one
Saeed Hamza
I'm trying to cut this mesh according to the triangles in the second picture, but i can't find a function to create a triangle from 3 points.
This is to create a solid replica of the silicone in this image:
Solved, i was able to draw the lines to make the triangles myself when i turned on 3d sketching.
