Creating Threads on a Cone
Hi!
I'm very new to Fusion360 and just starting to learn how to create 3D Models. I currently am trying to make a soft button release for one of my camera and having a hard time figuring out if it's possible to create threads on a cone that I created. When I created the cone I used the left option to where I created two different sized center diameter circles and then lofted them into a cone. When I try to select the threading option under create it doesn't allow me to choose the cone part for threading, just a sketch that is a complete circle. Is it maybe because I used the loft option for creating the cone? Any help/step-by-step would be greatly appreciated!
Fusion's Create Thread tool will only allow you to make threads on a cylinder, but you can use a Helix as a workaround.
Does this image show the type of geometry you are after?
Screencast - Making Tapered threads in Fusion360
https://www.google.com/search?q=tapered+thread+fusion+360
Hey! Thank you so much for responding. Yes! That is the exact thing I'm trying to achieve. Is the video you posted how I can achieve this? Thanks again!
bgRXDSS
Observer
Observer
Cool thx.
etfrench
Do you need threads on a cone?  If so:
  1. Create  your cone.
  2. Create a helix in the surface workspace with a surface sweep.
  3. Use split body or split face to create the path on the cone.
  4. Use a sweep using the thread profile and the path on the cone.
ETFrench
bgRXDSS
Observer
Observer
Hi i did not se the angle setting the first time around, but after trying
for half a hour I found the setting 😁
