- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I am trying to create an shaft to hold inline skate wheels at both ends fastened with lock nuts.
To do so I create the shaft, say 12mm dia, then I add a thinner section on the end, say 8mm dia, to fit a standard 608 skate bearing, then I cut M8 thread at the end of the shaft, and I place a M8 nut, and I want to assemble the nut on the thread.
I get to the assembly phase, but I cannot figure out how to place the nut on the thread.
Questions:
1) When I create thread, say for M8/1.25, do I make the shaft 8mm, or do I make the shaft thinner to match the inside of the thread?
2) When I import an M8 bolt, say from McMasters, do I use STEP format of SolidWorks format, they appear the same, but the STEP file is much smaller?
3) Is there an easy way to snap the imported part to the center of the bolt/rod, or to snap one surface in the part against anotehr surface, without needing to super zoom and move around?
4) How do I account for tolerances in CAM, i.e. if the shaft is 8mm and the 608 bearing ID is 8mm, do I just leave it as a perfect fit, or do I specify some smaller dimension to ensure it can move by hand?
5) How do I assemble the nut on the thread so it models motion, i.e. thread in and out, or if not supported, how do I model it to spin in place?
Thank you
