Creating spiral
Creating spiral
SimonPlatten
Message 1 of 17
Creating spiral
SimonPlatten
I don't feel like I am making much progress, here is an image of what I have:
 So far this is just the coil, I want to create a helix where the entry point is the at the top of the coil and is for example 20mm, then I want to join the bottom of the helix to the centre of the dome which is 10mm.  I want this to be a spiral, I am struggling to connect the coil to the ovals top and bottom.
I'm trying to follow this:
https://www.youtube.com/watch?v=8WW2_HtuV9A
And so far I have this:
Replies (16)
Message 2 of 17
SimonPlatten
Now I'm having problems with the different object types where the coil was created as a solid object an the bit I need to trim was created in the surface menu, it seems one isn't compatible with the other so I cannot use trim.
Message 3 of 17
HughesTooling
I don't have time to go through all of this again. The method in the YouTube vid is not the best.
I would create the helix using sketch and a Surface Sweep as this will be fully parametric.
Then use a tapered extrude set to intersect to create the tapered helix.
Now create 2 planes along path at each end of the tapered helix and sketch your tube profiles.
Then loft. This is all controlled using parameters.
File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 17
SimonPlatten
Thank you, I will try again.
Message 5 of 17
HughesTooling
Here's another version of the model. I've moved the part into a component so now you can copy it into your design and position and orientate using joint. Use the component origin to position in you design. I hope you've created the rest of your assembly following Rule #1 using components.
Marh
Mark Hughes
Message 6 of 17
SimonPlatten
I've downloaded the file and am looking at it, but not at the moment able to replicate.  On your first sketch1, there is a line that is dot and dashed, what is this and it looks like there is a constraint....looking at the sketch doesn't help a noob like me, do you have any instructions to go alone with it?
Message 7 of 17
HughesTooling
I just set the vertical line to Centre Line type as it is helpful when creating revoled type parts. The lengths are set using parameters.
You can view and adjust parameters here.
The sketch is used in the sweep to create the helix
Mark Hughes
Message 8 of 17
SimonPlatten
Thank you.
Message 9 of 17
SimonPlatten
[Edit] posted edited to remove silly question.
Message 10 of 17
SimonPlatten
Please see attached screen shot.
In my sketch the line that is shown in black according to your screen shot is to go into Profile, but I can't set it to the Profile, it will only go into the Path.
[Edit] Resolved....
Message 11 of 17
HughesTooling
[Edit] Resolved....
I guess you figured this out? Looks like the vertical line got automatically selected when you started the sweep feature?
Mark
Mark Hughes
Message 12 of 17
SimonPlatten
How do I get the "fx" menu option shown in your screen shot?  It doesn't appear on any of the tabs I have, I'm using version:
Fusion 360 2.0.16265 x86_64 [Native]
Active Plan: Personal
macOS 12.6.6 (21G646) on iMac17,1
Message 13 of 17
HughesTooling
It's on the modify menu.
Mark Hughes
Message 14 of 17
SimonPlatten
Thank you, on your screen shot earlier it appeared at the top level.  On your example, you have both lines in the same sketch and I've tried to replicate what you have, yours are not joined, in my sketch they are joined so I cannot select each for a separate selection.
Message 15 of 17
SimonPlatten
What is this constraint and how was it created?  I'm referring to the purple dot.
Message 16 of 17
laughingcreek
... in my sketch they are joined so I cannot select each for a separate selection.
try deselecting this in the sweep dialog-
Message 17 of 17
SimonPlatten
Thank you, I need the helix the other way around, so the sketch is flipped, but the results are not the same:
 [Edit] I think I can see my mistake now, I need to set-up the parameters and use Turns in the sweep.
