Bend a flat cable
Bend a flat cable
edenzr
Message 1 of 8
Bend a flat cable
edenzr
Hi there,
I have been using the spline tool to model cables and wiring in my assembly.
I recently have had there requirement to model flat cables, and to bend these cables in complicated ways.
Here is an exmaple of how I would like to bend the flat cable:
I can't seem to find a simple way to achieve this in the assembly without creating a new part.
I would like to be able to directly model this cable in the assembly (as you can do with a spline) to make it easy to find the most efficient path of the cable (since I need to route around components in the assembly).
Here is my attempt, but I can't seem to find a way to "bend" the cable.
Any help is appreciated!
Replies (7)
Message 2 of 8
HughesTooling
You'll only be able to do this by editing the spline in the sketch. Make the sketch visible and use move to move the spline nodes around, the model should update each time you stop moving a point. You're going to need the minimum amount of nodes in the spline you can get away with.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
edenzr
Just to confirm, what your saying is to have a high density of control points on the spline so that the spline bends as I want? I am not sure that this will result in what I need. If I have a rectangular profile how can I bend it and change its tangent to the path? I have been unsuccessful so far.
Message 4 of 8
HughesTooling
No what I meant was the opposite, you need as few points as you can get away with. But looking at your example with twists as well not sure it will work. Maybe with multiple sketches along the path you can rotate them and use a loft with the spline as a centre line. Not going to be easy in Fusion.
Mark Hughes
Message 5 of 8
TheCADWhisperer
@edenzr
You can do this in Autodesk Inventor Professional >>Wire and Cable Harness<<.
Message 6 of 8
davebYYPCU
In Fusion, (without actual data to review)
I would tackle this with Sweep, Path (Centre Line) and Guide Rail,
Various profiles on the path, and build the rail, from common point on the profile.
(Loft is finicky, we can’t select independent rail types in the Loft Dialogue.)
might help....
Message 7 of 8
edenzr
I've used sweep and paths quite a bit but never guide rail. Would you be able to explain what you mean by that?
Message 8 of 8
davebYYPCU
When Sweep with twist will not get there.
Might help....
