Constraints of a Circumscribed Polygon
Drewpan
Advisor Advisor
Drewpan
Hi All,
I have drawn a Circumscribed Polygon shown below but I cannot work out what it needs to be Constrained.
According to the Documentation, it uses a defined point (in this case the Origin) and another point for the
mid-point of the Polygon Side (in this case tangent to the construction Circle). It automagically calculates
the side length and angles. In theory it IS constrained (in MY Mind - but I am probably losing that😎).
I have tried a number of Constraints such as Length of Side and Tangent but it gives constant Over-Constrained
Errors. I don't know what it needs to be Constrained.
Any thoughts or solutions would be helpful.
Andrew
TheCADWhisperer
Click and drag “horizontal” line. (You might have to grab it at one of the endpoints.)
What do you observe?
Drewpan
What I Observe is that the Polygon rotates around the Origin, which I had not realised. My (wrong) assumption
was that it would be locked down. On thinking about it I changed the Construction line to an actual line from
the Origin of the correct length then made the Mid-point of one Polygon side Coincident to the end of the
Construction line and it locked down immediately. Not actually obvious to those of us with our "inexperienced
Blinkers" firmly in place.
Thank you.
Andrew
TheCADWhisperer
@Drewpan
What you should have observed is that the “horizontal” line is missing a Horizontal Constraint.
Drewpan
When I initially tried before I posted that alone didn't work.
After you suggested it I went back and tried again and it worked but also needed Tangent to the Construction
circle. That is what confused me because I needed two Constraints that were not obvious.
Andrew
