creating pipes and wires in multiple planes
Message 1 of 8
how should i create pipe and wires that are necessarily not in the same plane, using 3D sketching is quite a cumbersome and hard process, is there any other way?
Replies (7)
Message 2 of 8
g-andresen
show pictures of a real existing object
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
Message 3 of 8
i cannot share my working file as it is a project which i cannot disclose,  my question is how to create pipe which connect to fixtures not in same plane while avoiding other bodies in the design.
Message 4 of 8
TheCADWhisperer
Make up a dummy file that exhibits the same behavior.
I use Intersection of 2D to get 3D path.
Message 5 of 8
shahriarsifat1802164
Hi @Anonymous ,
So my opinion is to make a general model and then copy it several time and place theme one by one. At last combine them as a single body.
If you have any query feel free to ask.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 6 of 8
g-andresen
@Anonymous wrote:
...  my question is how to create pipe which connect to fixtures not in same plane while avoiding other bodies in the design.
Yes that´s possible!
If you show some basics of the construction e.g. as a hand sketch, one could give hints.
günther
Message 7 of 8
TheCADWhisperer
I have a query, "Can you post a Screencast recording of your suggested technique?"
Message 8 of 8
chrisplyler
Planes that are not parallel do cross each other somewhere you know.
If you're not happy with a single 3D sketch... Create multiple planes where you want the runs to go, and connect the endpoints of lines on one plane with the endpoints of lines on another plane.
