Fixing an imported model
This is driving me nuts so hopefully someone can help!  I want to model pressure on a section of spine so have an imported model I found online created from an MRI scan by someone else.  I want to put a section together then upload to SimScale for FEA analysis.
However when uploaded to SimScale as step, it says there are intersecting surfaces which is, I guess, not unexpected.
My question is....how do I fix this in Fusion 360?  Any help would be greatly appreciated. I attached the original solidworks file.
TrippyLighting
The Inspect menu has a Validate function, which can help repair geometry.
If that helps to repair this particular geometry for use in external FEA software is another question.
shahriarsifat1802164
If you want to repair some geometry go to the validate option belongs to the inspect toolbar.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
TrippyLighting
I answered that question the same way just in the post before yours. Perhaps, before responding to every thread under the sun, make sure you read previous posts!
