Creating multiple parts from the same base design
todd.trainnut
todd.trainnut
I am trying to design a painting mask for painting model train wheels (what a nerd, right?). The problem is, not all train cars have the same size wheels, so I'd like to make a mask for 28", 33", and 36" scale wheels. My thought was to create a base blank design, then import that design into 3 different final designs where I would cut the appropriate sized hole for the wheels. I'm designing the mask in 2 identical halves that slide together (making 3D printing the mask easier).
Here's the blank design:
The problem I'm encountering is that once the base design is imported into one of the final designs, I can't cut the holes in it due to the link. I'd like to preserve the link so that if I need to change the geometry of the mask, I can just change the base design rather than changing all 3. Is what I'm trying to do possible?
I'm not very experienced with CAD, so it's totally possible I'm approaching this the wrong way. Thanks for your help.
MRWakefield
Have you tried 'Insert Derive' from the 'Insert' menu? I think it should do just what you want.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
TrippyLighting
Importing triangulated geometry is really not the best way to work with anything in a CAD software ... even for a nerd 😉
todd.trainnut
Oh hush. I got the design from a friend as an STL to print, decided to make some improvements myself, and didn't want to re-draw the whole thing.
todd.trainnut
That did it! Thanks for your help!
