Simulation warning
Simulation warning
Simulation warning
All,
I am completely new to CAM and F360. I am following youtube videos to help educate myself. With that said I am following one video in particular helping me with simulations.
1. I selected "preserve region"
2. Selecting the area
3. Select "solve"
4. Select "solve" in the sub menu
Then a window opens so I can select the study
5. I select "Solve 1 Study"
then I get this error:
Warning: Warning: Constraint Fixed3 references same entity like another one.
I am sure you all will need more info, but here are some screenshots.
554411
tyler_henderson
This happens when you apply a Constraint multiple times to the same entity (face, edge, or vertex).  So expand the Load Case folder in the browser and find "Fixed3" under the Constraints.  Likely you have another Fixed constraint at the same place causing redundancy.  You can delete one of those Constraints.
Tyler Henderson
Principal User Experience Designer
