Creating flat pattern with details
I am modeling some sheet metal parts and I want to be able to create a flat pattern drawing that includes all the neccesary details for forming. Bend line distances and angles. I have figured out how to manually add linear measurements, but not the required bend angle. is there a way to do this? automate it? Also the hole sizes are important.
Thanks.
jhackney1972
To call out the bend angles, in the flat pattern drawing, you use the Table function.  The table automatically recognizes the drawing view as a flat pattern and gives you the bend angles and direction.  You can modify the callout locations by dragging and add a leader.  Hole dimensions are like any other drawing.  Take a look at the Screencast.
John Hackney, Retired
Thank you so much! That clarified everything.
David.
