Creating chamfers/fillets on part of an edge
I'm a total newbie when it comes to any kind of CAD, so this is probably a pretty stupid question.
For shapes like guitar bodies with lots of bevels, soft edges and curves, how can I vary the depth of a chamfer along an edge? Also more importantly, how can I chamfer/bevel partially along an edge rather than the full circumference of the body?
Here's an Illustrator mockup of the kind of thing I want to achieve
Any advice is appreciated!
jeff_strater
I would model the "chamfers" first, and then the fillets second.  I put the "chamfer" in quotes, because you don't really want to use the Chamfer feature to do this.  Personally, I would use a Sculpt/Form feature to create a surface, and use Split Body to do that cut.  There are other ways, including Loft, maybe Sweep, of doing those cuts.
Here are a couple of related threads:
Jeff Strater
Engineering Director
