Exporting drawing
Exporting drawing
kshea9RNL8
Exporting drawing
kshea9RNL8
Is it not possible to export a drawing to local computer?
The File>"Export" highlights but does nothing, same with File>"Save",  File>"Save As" functions noprmally
suryawa
Hi @kshea9RNL8,
Yes, It is possible to export a drawing to local computer but not in traditional way;
"Save As" option in current context allow user to change Name, Type (*.f2t, *.f2d) & Location within Data Panel only.
To get a local copy on computer, try the follwing method:
> Explore the file in Data Panel - then RMB on it.
> Use option "Share Public Link" [Select appropriate options in the dialog]
> By using the link generated in above step, it shows a Download option in Browser.
> Someone can download the Fusion 360 Archive file at desired destination.
Sample Fusion File Formats:
>> *.f3d, *.f3z, *.f2t, *.f2d)
Hope it helps...
--Amit
Amit Suryawanshi
SQA Fusion 360
lichtzeichenanlage
A drawing behaves like a linked component (a Fusion 360 design separated in several files). The desktop client is not able to export distributed designs but you can do this in the WEB-client by clicking on your project title in the data panel and choosing the download format. After a short time you'll get a download link via email.
Be aware that the Fusion Archive file will contain not only the drawing but the design, too. That's the nature of linked files within Fusion 360.
kshea9RNL8
Thanks for the help guys.
