- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to create and "off center" assembly of 2 components so I can cut one of the pieces and create a slot. I have done this when there was some type of symmetry to drive the "assembly" feature but I cannot find one here. I think the attached screencast will show it.
In the screencast I have manually moved the parts to approximate positions and done the "cut" to show what I am trying to accomplish. I basically want a slot symmetrical along X of the box. One face of the slot coincides with a plane intersecting the "middle face" of the construct, the top faces of both the "slot" and box coincide.
This problem seems to open a whole issue about joining pieces for unions and cuts in general. I have used individual "components" as this seemed to be the prevalent suggestion on this forum although I expect there are other ways to do it. I cannot do it aligning sketches without going to a 3D geometry and I further doubt that this is what is intended in Fusion.
Any help appreciated
Fritz
https://knowledge.autodesk.com/community/screencast/7b3eeb8e-c7c3-4a61-a62e-5b6873de657d
