Finding Minimum Distance Between Two Faces?
chris_uvic
chris_uvic
Using Fusion 360 with a few components in a design, I'm trying to measure the minimum distance between two objects. What seems to make this tricky with Fusion 360 is that the closest faces to each other on these objects are curved. If I use the measure tool, Fusion 360 either gives me the distance from their center points. As well, while one of these bodies has a snap point that may be in the closest position, the other does not.
I assume I'm missing something here, but a lot of searching has not provided an answer.
Does anyone know the solution?
Thanks!
laughingcreek
depends on the circumstance.  a file would help.  at least a screen shot
shahriarsifat1802164
Please drag and drop your file.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
RUET
Thank you.
