Creating an Actuator with a second Join
pa7duodu
pa7duodu
Community Visitor
Community Visitor
I am trying to make an actuator that will push down on a wing piece, which will in turn rotate about an axle.
I have been able to make the actuator shaft move in and out of its hole and I have been able to make the wing piece rotate about the axle, but I can’t figure out how to make the shaft and wing piece interact.
In other words I can’t get the shaft to push down on the wing piece.
please give any help if you can
TheCADWhisperer
If your actual data is proprietary simply make up a dummy mechanism that exhibits the same behavior.
jhackney1972
The Forum users really need to see and work with your model to begin to give the answer.  Please attach it.  Open your model in Fusion 360, select the File menu, then Export save to your hard drive.  Attach it to a reply post using the Attachment section.
John Hackney, Retired
Warmingup1953
Is this a pitch change link/actuator for a Gyrocopter or helicopter? More details please.
