I'm looking for the best way to make a slot on the side of this little bracket. I've attached the Fusion file for reference.
The issue I'm having isn't that I can't do it, but that the way I am doing it seems to be convoluted, and that it seems like there must be a better way.
When I am placing the slot, I know where it needs to go, but I'm not sure exactly how I should define those dimensions ahead of time. So far, the best way I've been doing for a couple years now is to create points at the correct dimensions by first creating planes that are the correct distance from existing geometry. That allows me to use the points that I know as a reference in the sketch.
However, every time I open a sketch, it occurs to me that the whole process would be much easier and take like a order of magnitude less time if I could simply place a line or point in relationship to geometry while I'm sketching. For example, first define an edge or vertex and then enter a distance to traverse before starting the line (or slot or hole or whatever).
This seems like such a simple thing to be able to do that I can't wrap my head around it not being an option. Am I missing something really important here, or is this just a limitation of AutoDesk software (or just a gimped feature that isn't available in Fusion to create software tiering)?
已解决! 转到解答。
