Creating a sheet metal part on a curved object
I have tried for a few hours now and can't figure out how to create a 1mm thick sheet metal on this curved top surface.
Thanks!
TrippyLighting
You mean like this ?
thanks a lot!
feels like this should be a feature in sheet metal.
davebYYPCU
It is.
so that I can select the surfaces and it "thickens" my sheet metal onto the body?
etfrench
No, the key is to select the profile in the sketch.
ETFrench
I see.
The workaround required when the width of your sheet metal varies is, that you have to trim it with a thickened body , and not along one vector, as I did before. This gave me multiple edges in my flattened dxf file.
Thanks for your help!
