- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using constraints I can make the initial sketch with only one numeric value. You then have to extrude and give it a value to make the cube. How can I use a constraint from one sketch to another? I know I can create a variable and use that but I am looking for a way to have one sketch reference another and the perfect cube is a simple example that people/I can understand.
