Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Creating a LED strip
7 REPLIES 7
Message 1 of 8
2931 Views, 7 Replies
Hi to all,
I am a student and a fusion 360 enthusiast and I have been doing some 3D models for some time now. Recently, I had to do an LED strip for my class but when I finish my work the strip looks sloppy and unrealistic.
I am going to attach picture of what exactly am I looking for.
If anybody has any suggestions on how to make my work flow easier and some tips on how to create that LED strip, that would be amazing and I would really appreciate it.
Kind regards
Tags (2)
7 REPLIES 7
Message 2 of 8
TrippyLighting
A screenshot of the LED strip you modeled would be helpful and perhaps attach the model you created (export as .f3d)
Message 3 of 8
in reply to: TrippyLighting
Thanks for the fast reply!
I have attached my poor attempt for a Led strip .I managed to get a nice flowing flat-ish shape for the actual strip, but when it come s to putting the LED's on it , using a Pattern, they are not't placed in a natural way and it looks sloppy. I have tried pretty much everything I can think of but I just can't manage to get the small LED ( the rectangles) to be placed on the strip with a flow, like the ones on the  screenshot I've posted in my fist post.
Kind regards
Message 4 of 8
PhilProcarioJr
@Anonymous
See if this helps you.
keep in mind this file and video is just to show you a concept I did not use components. You should definitely use components properly if your going to do this.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 5 of 8
in reply to: PhilProcarioJr
Thank you it is of great help !
Message 6 of 8
PhilProcarioJr
@Anonymous
I might add that you can make the pattern components as detailed as you want. With a good texture on the strap and some chip decals you could make your model very realistic.
Did this answer your question?
Phil Procario Jr.
Message 7 of 8
That is all of extreme help thank you very much!
However, my trouble is also with how to make the strip have a twist, so both the LED side and the back side can be seen. I am aiming for something like the screenshot I posted at the beginning - a model on which both the back and front side can be seen. I am going to attach my file so you can se with the drawing what type of curve I am aiming at.
Message 8 of 8
PhilProcarioJr
@Anonymous
I don't know of any way to do that other then manually rotating the parts into place. Sorry.
Phil Procario Jr.
Technology Administrators
