Hello friends,
What I want to achieve is have 4 holes, in a 90mm square pattern, perpendicular to the surface on a sphere surface.
The closest I got to my goal was using projected sketch, but the holes seems to be "drilled" straight down, instead of perpendicular to the surface:
I noticed that if I choose to create the hole directly on the surface of the sphere (without using the sketch points as guides), the hole is drilled correctly, but I have no control over hole spacing and pattern:
I also tried to project circles and then to use press/pull to create the holes, but first, it didn't work (I can't choose the projected sketch for pull/push), and second, I would prefer to use the Hole tool, as I would like to make the holes countersunk and the Holes tools helps with that a lot.
Any help would be greatly appreciated!
Thank you!
