I am new to fusion 360 and I am having a terrible time trying to figure out how to cut multiple vertical slots evenly spaced on a cylinder. Like the picture below. I have been struggling for days.
Solved by Ajay_Kumar_Reddy. Go to Solution.
Solved by g-andresen. Go to Solution.
Circular Pattern.
Sure. I believe this is the file. I made 1 slot, but can't figure out how to duplicate it across the cylinder.
@Hey @scottafriedman,
You did a great job in creating the cylinder and slot.
but you need little understanding, using the pattern, pipe, shell.
They'll make a beautiful job, check out the file you'll get to know.
You guys are awesome. Thank you. I was doing it the long way by creating copies of each slot and then moving them slightly to change the hole on the cylinder.
Thank you again!
I'm glad it worked.
Please mark contributions that made a solution by checking them as "Accepted Solution".
This will make it easier for future readers.
günther
