Create mulitple slots on a cylinder
7 REPLIES 7
Message 1 of 8
scottafriedman
666 Views, 7 Replies
I am new to fusion 360 and I am having a terrible time trying to figure out how to cut multiple vertical slots evenly spaced on a cylinder. Like the picture below. I have been struggling for days. vortech-mp40-qd-nozzle_1.jpg
7 REPLIES 7
Message 2 of 8
Circular Pattern.
Message 3 of 8
Sure.  I believe this is the file.  I made 1 slot, but can't figure out how to duplicate it across the cylinder.
Message 4 of 8
g-andresen
in reply to: scottafriedman
try this
günther
Message 5 of 8
g-andresen
here is a model like the one in your 1st post
Screencast
günther
Message 6 of 8
scottafriedman
in reply to: g-andresen
You guys are awesome.  Thank you.  I was doing it the long way by creating copies of each slot and then moving them slightly to change the hole on the cylinder.
Thank you again!
Message 7 of 8
g-andresen
I'm glad it worked.
Please mark contributions that made a solution by checking them as "Accepted Solution".
This will make it easier for future readers.
günther
Message 8 of 8
@Hey @scottafriedman,
You did a great job in creating the cylinder and slot.
but you need little understanding, using the pattern, pipe, shell.
They'll make a beautiful job, check out the file you'll get to know.
