I created a part with a tapped hole, 1.25 with 8TPI UNC. I get a message "select linear or circular reference edges to fully define hole location", I cannot seem to be able to select a reference. I have the face selected and hole positioned. countersink, threaded hole, etc, the picture shows the threads, but when I export to STL, the threads do not display and the 3D print is smooth with no threads. please help
Solved by TheCADWhisperer. Go to Solution.
Solved by g-andresen. Go to Solution.
Do not put the countersink in the Hole feature.
Add a Chamfer after the Hole.
Now right click Edit the Hole and change the thread from Cosmetic to Modeled.
