Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Create a tapped hole for 3D printing
3 REPLIES 3
lasuarez1
901 Views, 3 Replies
I created a part with a tapped hole, 1.25 with 8TPI UNC.  I get a message "select linear or circular reference edges to fully define hole location", I cannot seem to be able to select a reference.  I have the face selected and hole positioned. countersink, threaded hole, etc, the picture shows the threads, but when I export to STL, the threads do not display and the 3D print is smooth with no threads.  please help
3 REPLIES 3
g-andresen
in reply to: lasuarez1
enable "modeled"
günther
TheCADWhisperer
Do not put the countersink in the Hole feature.
Add a Chamfer after the Hole.
Now right click Edit the Hole and change the thread from Cosmetic to Modeled.
lasuarez1
thank you for your help, I was successful in my 3D print 😀
