Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Create a tapered slot
3 REPLIES 3
ponzi_chris
139 Views, 3 Replies
I am drawing up a facemill cutter that I will be useing to surface heads on model A's. I need to put a tapered 1/2" wide slot in the bottom surface. I would like the taper to be 10 degrees, how would I do this, im at a loss.
share link: https://a360.co/4b70ITQ
3 REPLIES 3
CGBenner
in reply to: ponzi_chris
@ponzi_chris
Welcome to the forum, I have moved your post here to the Design forum for better visibility.  Good luck.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
davebYYPCU
Origin sketch  draw the roof line, extrude symmetric.
Might help....
ponzi_chris
THANK YOU! I knew it was easy! That was driving me nuts. I got it
Technology Administrators
