I am drawing up a facemill cutter that I will be useing to surface heads on model A's. I need to put a tapered 1/2" wide slot in the bottom surface. I would like the taper to be 10 degrees, how would I do this, im at a loss.
share link: https://a360.co/4b70ITQ
Solved by davebYYPCU. Go to Solution.
@ponzi_chris
Welcome to the forum, I have moved your post here to the Design forum for better visibility. Good luck.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
